- Mute
- Permalink
- Report
Macro - Ilogic - Which is the best opton.
I am have trouble switching my brain over to inventor after switching from Solidworks.
I need something very simple, we have 50,000 parts that will not migrate using the task scheduler so wer are manually opening up a handful than go throught the "rebuild" "save" and "close"
Does anyone have the cose that I could run on all open files - Rebuild-Save and Close
Some of these files go back to Beta6 ![]()
A little Help qould be great.
Thanks in advance
and this Invenotr stuff is a little more stable than SW at the moment.
- Mute
- Permalink
- Report
If you get code or make it, it will be something super easy like:
HOWEVER, this will go through every document that is visibly open. Erase '.VisibleDocuments' for it to go through all of them.
I haven't tested this, but it should work for you.
Dim oDoc As Document
For Each oDoc in ThisApplication.Documents.VisibleDocuments
If
With oDoc
' .Activate
.Rebuild
.Save
.Close
End with
Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Sent from my iPhone
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Simply reading things usually goes a long way in programming;
Ran that code.
The error stack that came back:
Error on Line 2 : 'If' must end with a matching 'End If'. Error on Line 2 : Expression expected.
Oh heyyyy. Look, the code doesn't have a matching End If/ The If that is there is useless, so delete it.
With oDoc
' .Activate
.Rebuild
.Save
.Close
End With
NextAnd then....
Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED)) System.Runtime.InteropServices.COMException (0x8000FFFF): Catastrophic failure (Exception from HRESULT: 0x8000FFFF (E_UNEXPECTED)) at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData) at Inventor.AttributeSet.get_Name() at iLogic.RuleStorage.RuleInDocumentForEqualsTest.GetHashCode() at System.Collections.Generic.ObjectEqualityComparer`1.GetHashCode(T obj) at System.Collections.Generic.HashSet`1.InternalGetHashCode(T item) at System.Collections.Generic.HashSet`1.Remove(T item) at iLogic.RuleAndTriggeredEval.EvalRule() at iLogic.RuleEditAndRun.RuleEvaluate(RuleEvalContainer ruleEvalCont) at iLogic.EditRuleRunner.RuleModifyAndEval(ILmiRule ruleNodeDef, Boolean& cancelled)
So yeah something bigger actually is wrong. But it still runs the rebuild/save part. It just doesn't like closing files.
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
I have done close to 5,000 ipt files this morning, but I was given a list of assemblies too.
I will need something, but thanks for your input at lunch hour I am going to re-post the code her so others may use.
- Mute
- Permalink
- Report
Ilogic for Rebuild and Save all .ipt Files
With oDoc
' .Activate
.Rebuild
.Save
.Close
End With
Next
- Mute
- Permalink
- Report
Alt + G + J + K + T + R
trigger=iTrigger0
Dim oDoc As Document = ThisApplication.ActiveDocument
With oDoc
' .Activate
.Rebuild
.Save
.Close
End With
- Mute
- Permalink
- Report
Also, Rebuild does not work on drawing files. Best you can do it .Update. Which might be what fixes the other issue for you anyways.
so
If oDoc.DocumentType() = kAssemblyDocumentObject Or kDrawingDocumentObject
With oDoc
' .Activate
'.Rebuild
.Update
.Save
.Close
End With
Else
With oDoc
' .Activate
.Rebuild
'.Update
.Save
.Close
End With
End if
Next
