- Mute
- Permalink
- Report
In my recent coding I came across some issues with defining documents and getting a LateGet Error, so I was wondering what the actual best practice for doing this is or what the difference may be.
I need to switch between multiple documents during one rule.
-> By Using oDoc = ThisApplication.ActiveDocuments<- Does this hold the same document even if i switch documents, or will it just pull the active document again?
By using oDoc = ThisApplication.Documents.ItemByName()
BY using oDoc = ThisApplication.Documents.ItemByName().Open
Or with oDoc = .... .AddUsingTemplate()
Is there a difference in how they define and call the document?
This all results because I used the oDoc = ... .AddUsingTemplate and then called the file using oDoc later on, after switching documents multiple times, and then kept on getting a .LateGet / LateBinding error.
So for my work around, I had just added in a function that accessed the active document, which was my new document, to add a title block.
Any help/insight would be helpful!
Sub Main()
For Each oSheet In ThisApplication.ActiveDocument.Sheets
Dim sPromptStrings(4) As String
Try
sPromptStrings(0) = oSheet.TitleBlock.GetResultText(oSheet.TitleBlock.Definition.Sketch.TextBoxes.Item(48)) ' Title
sPromptStrings(1) = oSheet.TitleBlock.GetResultText(oSheet.TitleBlock.Definition.Sketch.TextBoxes.Item(49)) 'DESCRIPTION 1
sPromptStrings(2) = oSheet.TitleBlock.GetResultText(oSheet.TitleBlock.Definition.Sketch.TextBoxes.Item(50)) 'DESCRIPTION 2
sPromptStrings(3) = oSheet.TitleBlock.GetResultText(oSheet.TitleBlock.Definition.Sketch.TextBoxes.Item(52)) 'CUSTOMER DRAWING#
sPromptStrings(4) = oSheet.TitleBlock.GetResultText(oSheet.TitleBlock.Definition.Sketch.TextBoxes.Item(53)) 'SCALE
Catch
End Try
oFileDoc=ThisApplication.Documents.Add(kDrawingDocumentObject,"C:\User.idw", True)
oSheet.CopyTo(oFileDoc)
oFileDoc.Sheets.Item(oFileDoc.Sheets.Count).Activate
oFile = "C:\" & oSheet.TitleBlock.GetResultText(oSheet.TitleBlock.Definition.Sketch.TextBoxes.Item(52)) & ".idw"
'Directory and comments.
oFileDoc.Activate
If Not oFileDoc.ActiveSheet.TitleBlock Is Nothing Then
oFileDoc.ActiveSheet.TitleBlock.Delete
End If
Dim oTitleBlock As Inventor.TitleBlock
oAddTb
MsgBox("oAddTb Ran Successfully!")
ThisApplication.ActiveDocument.Sheets.Item(1).Delete
ThisApplication.ActiveDocument.SaveAs(oFile, False)
' oFileDoc.Close
Next
End Sub
Function oAddTb
'Dim oSheet As Sheet = ThisApplication.ActiveDocument.Sheets.Item(ThisApplication.ActiveDocument.Sheets.Count)
Dim oSheet As Sheet = ThisApplication.ActiveDocument.ActiveSheet
sPromptStrings(0) = "A" ' Title
sPromptStrings(1) = "A"
sPromptStrings(2) = "A"
sPromptStrings(3) = "A"
sPromptStrings(4) = "A"
If Not oSheet.TitleBlock Is Nothing Then
oSheet.TitleBlock.Delete
End If
oTitleBlock = oSheet.AddTitleBlock("LIB", ,sPromptStrings)
End FunctionThis is an example ( I am still running into issues passing the prompt strings to the function so that it can appropriately fill in my titleblock.) - oFileDoc was the part giving me issues.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
