rjay75
in reply to: ASchlaack
You have two options depending on how your rules are written in the part.
In your assembly you can have a rule that responds to a parameter change. That rule can then change the part parameter  or run a rule. If the rule in the part is an internal rule written using the parameter name then it will automatically respond to a parameter change in the part. If the rule must be explicitly run then that can be done to.
From the assembly:
Run rule in subcomponent:
iLogicVb.RunRule("Angle", "Length")
Modify a parameter
Parameter("Angle", "length") = 2.0 in
