03-17-2015
07:49 AM
- Mute
- Permalink
- Report
03-17-2015
07:49 AM
yuhanzhang,
My code is basically the same as yours except that I also check the DerivedAssemblyComponents.Count. However, as soon as the SetVisibility method is called on an occurrence of a derived component that is in a sub-assembly, the following error is thrown.
"Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))"
Have you tried your code out to see if it works in that situation?
Darren
Private Function HideAllDerivedPartsInSelectedView(ByRef SelectedView As Inventor.DrawingView, ByVal ShowParts As Boolean, ByRef SubAssemblyDoc As Inventor.AssemblyDocument) As Boolean
Dim AssemblyInView As Inventor.AssemblyDocument = Nothing
Dim AssemblyComponentDefObject As Inventor.AssemblyComponentDefinition = Nothing
Dim ComponentDefObject As Inventor.PartComponentDefinition = Nothing
Dim DocumentInView As Inventor.Document = Nothing
Dim OccurrenceCollection As Inventor.ComponentOccurrences = Nothing
Dim OccurrenceObject As Inventor.ComponentOccurrence = Nothing
Dim PartDocumentObject As Inventor.PartDocument = Nothing
Dim ReferenceComponentCollection As Inventor.ReferenceComponents = Nothing
Dim ReferencedDocObject As Inventor._Document = Nothing
Dim ReturnBoolean As Boolean = False
Try
If SubAssemblyDoc Is Nothing Then 'This is the first time the routine has been called
DocumentInView = SelectedView.ReferencedDocumentDescriptor.ReferencedDocument
If Not TypeOf DocumentInView Is Inventor.AssemblyDocument Then
MsgBox("The Document In The View Needs To Be An Assembly!", MsgBoxStyle.Information, "WRONG DOCUMENT TYPE!!!")
Exit Try
End If
AssemblyInView = CType(DocumentInView, Inventor.AssemblyDocument)
Else
AssemblyInView = SubAssemblyDoc
End If
AssemblyComponentDefObject = AssemblyInView.ComponentDefinition
OccurrenceCollection = AssemblyComponentDefObject.Occurrences
For Each OccurrenceObject In OccurrenceCollection
If OccurrenceObject.ReferencedDocumentDescriptor Is Nothing Then Continue For
ReferencedDocObject = OccurrenceObject.ReferencedDocumentDescriptor.ReferencedDocument
If TypeOf ReferencedDocObject Is Inventor.PartDocument Then
PartDocumentObject = CType(ReferencedDocObject, Inventor.PartDocument)
ComponentDefObject = PartDocumentObject.ComponentDefinition
ReferenceComponentCollection = ComponentDefObject.ReferenceComponents
If ReferenceComponentCollection.DerivedPartComponents.Count = 0 And ReferenceComponentCollection.DerivedAssemblyComponents.Count = 0 Then Continue For
'show or hide the occurrence of the derived part or assembly
SelectedView.SetVisibility(OccurrenceObject, ShowParts)
ElseIf TypeOf ReferencedDocObject Is Inventor.AssemblyDocument Then
'recursively go through the sub assembly and look for derived parts
HideAllDerivedPartsInSelectedView(SelectedView, ShowParts, CType(ReferencedDocObject, Inventor.AssemblyDocument))
End If
Next
ReturnBoolean = True
Catch ex As Exception
MsgBox(ex.Message)
ReturnBoolean = False
Finally
ReleaseCOMObject(AssemblyInView)
ReleaseCOMObject(AssemblyComponentDefObject)
ReleaseCOMObject(DocumentInView)
ReleaseCOMObject(OccurrenceCollection)
ReleaseCOMObject(OccurrenceObject)
ReleaseCOMObject(PartDocumentObject)
ReleaseCOMObject(ReferencedDocObject)
GC.WaitForPendingFinalizers()
GC.Collect()
End Try
Return ReturnBoolean
End Function
