03-16-2015
08:17 PM
- Mute
- Permalink
- Report
03-16-2015
08:17 PM
You can try below updated VBA code if it works, it will iterate all the sub occurrences and hide the derived part components:
Sub hideCurveOfDerivePart()
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
Dim oView1 As DrawingView
Set oView1 = oSheet.DrawingViews(1)
Dim oModelDoc As Document
Set oModelDoc = oView1.ReferencedDocumentDescriptor.ReferencedDocument
If oModelDoc.DocumentType = kAssemblyDocumentObject Then
Dim oEachOcc As ComponentOccurrence
For Each oEachOcc In oModelDoc.ComponentDefinition.Occurrences
'native part document (this part has derived part)
If oEachOcc.ReferencedDocumentDescriptor.ReferencedDocument.DocumentType = kPartDocumentObject Then
Dim oNativePartDoc As PartDocument
Set oNativePartDoc = oEachOcc.ReferencedDocumentDescriptor.ReferencedDocument
'check if the document has derived part
If oNativePartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Count > 0 Then
'hide the occurrence in the context of the drawing view.
Call oView1.SetVisibility(oEachOcc, False)
End If
ElseIf oEachOcc.ReferencedDocumentDescriptor.ReferencedDocument.DocumentType = kAssemblyDocumentObject Then
Dim oSubOccu As ComponentOccurrence
For Each oSubOccu In oEachOcc.SubOccurrences
HideDerivedComponent oSubOccu, oView1
Next
End If
Next
End If
End Sub
' Iterate all the sub occurrences and hide the derived part
Sub HideDerivedComponent(oOccu As ComponentOccurrence, oView As DrawingView)
If oOccu.ReferencedDocumentDescriptor.ReferencedDocument.DocumentType = kPartDocumentObject Then
Set oNativePartDoc = oOccu.ReferencedDocumentDescriptor.ReferencedDocument
Call oView.SetVisibility(oOccu, False)
End If
ElseIf oOccu.ReferencedDocumentDescriptor.ReferencedDocument.DocumentType = kAssemblyDocumentObject Then
For Each oSubOccu In oOccu.SubOccurrences
Next
End If
End Sub
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
