03-16-2015
08:59 AM
- Mute
- Permalink
- Report
03-16-2015
08:59 AM
Well, I posted the solution I was provided by ADN but I need to clarify that this solution only works in limited instances.
If the assembly in the drawing view contains a derived part then the solution works for making that part visible or not.
If the assembly in the drawing view contains a sub-assembly that contains a derived part, the solution does not work. In fact, if you drill down to the derived part and try to make it visible or invisible, the following error is generated, "Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))"
I have reopened my case with ADN to figure out what is going on but I have not heard back from them yet.
Darren
