407 Views, 2 Replies
[VBA] SetInspectionDimensionData Blank Label Issue
Gday all,
My goal is to create macros for everything I use the most so i can assign them single key hotkeys to boost my productivity. So I got the following code to set a dimension as an inspection with an angular border, but my issue is it creates a segment (vertical line) for the label even when the label it's set to be blank. Manually editing the dimension shows that the label is blank but if i press delete it removes the segment line.
Sub Dimension_Inspection()
  Dim oDoc As DrawingDocument
  Set oDoc = ThisApplication.ActiveDocument
  Dim oSSet As SelectSet
  Set oSSet = oDoc.SelectSet
  'reference to the selected dimension
  Dim oDim As LinearGeneralDimension
  Set oDim = oSSet.Item(1)
  Dim Shape As InspectionDimensionShapeEnum
  Dim Label As String
  Dim Rate As String
  Shape = kAngularEndsInspectionBorder
  Label = ""
  Rate = ""
  oDim.IsInspectionDimension = True
  oDim.SetInspectionDimensionData Shape, Label, Rate
End Sub
See the highligted segment. it's unnecessary and makes my drawings look inconsistant.
