- Mute
- Permalink
- Report
How to use iLogic to build a custom press brake forming table
Years ago I created an AutoLISP routine that we have been using in AutoCAD to create our forming tables that our press brake operators reference when manufacturing a part. I would like to create an iLogic routine that can create a similar style of table that includes the distance from the edge of the part to the bend line (from the flat pattern) and also include the magnitude of the bend. Ideally I would start by selecting the lower sheet edge and then continue to select bend lines until I reach the middle of the sheet. The routine would then build a table and insert the dimension and bend angle for each line that was chosen. I am just getting started with iLogic and searched through this forum and online and was not able to find much guidance. Any help is appreciated!
thanks,
Mark
