687 Views, 3 Replies
Looking Rule to delete all Rules in ipt
Hi all,
I am looking for help for the below requirement
I have few Inventor parts, using 'SaveCopyAs' command I am creating copy of all these files and saving it in separate folder.
I am looking for Rule that deletes all the Rules in the newly created Inventor part file (.ipt)
Any help will be greatly appreciated
Rudresh
LukeDavenport
Hi Rudresh,
You can do this manually with the below command
[image: Inline image 1]
Alternatively, here is a blog I wrote with an iLogic rule to delete all
rules in the active part (or assembly)
https://www.cadlinecommunity.co.uk/hc/en-us/articles/202020531-Inventor-2015-iLogic-Delete-All-iLogi...
Best regards,
Luke
Sorry this was the command I was referring to.
in reply to: LukeDavenport
Thanks Luke,
I used the Logic that you have refferred, had to change some lines. It worked fine..
Rudresh
