isocam
1014 Views, 2 Replies
Export "DWG" select a face using a VBA macro
Can anybody help????
I have the following code that outputs an AutoCAD "Dwg" file of an extruded face. The output is a 2d profile.
        Dim oDoc As PartDocument
        Set oDoc = ThisApplication.ActiveDocument
        Dim oBaseFace As Face
        Set oBaseFace = oDoc.SelectSet.Item(1): THIS IS THE PROBLEM LINE!!!!
        Dim Cm As CommandManager
        Set Cm = ThisApplication.CommandManager
        Call Cm.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent,"C:\Test.dwg")
        Dim oCtrlDef As ButtonDefinition
        Set oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("GeomToDXFCommand")
        Call oCtrlDef.Execute
It works fine but I have to pre-select the face of the extrusion manually before running the macro. Does anybody know how to automatically select the face using the VBA macro rather than manually selecting the face first?
All I am doing is creating a sketch (Lines/Arcs/Circles) then extruding the sketch. Nothing else!
Many thanks in advance!!!!
Darren
