- Mute
- Permalink
- Report
Updating every sheet of every idw? (Inventor 2014)
Hi everybody,
I often have to change several assemblies (iam) at once which isn’t too difficult: I can open all of them at once, do the changes in each iam and then save and close them at once.
Now, these assemblies have a drawing (idw) each which I have to update afterwards. I can open all of them at once, too, and the first sheet will be updated automatically as soon as each idw is opened.
However, every idw has more than just one sheet in it. And the non-active sheets will not be updated when the idw is opened.
I’m looking for a solution using iLogic/VBA. So, all of the idws are opened and one of them is active. The macro shall simply update every sheet of the active idw, then switch to the next idw, update every sheet there, switch to the next idw … and so on until every idw has been completely updated.
I’m quite familiar with VBA in MS Excel, but I simply don’t know the correct commands in Inventor.
Can anyone help me, please?
Regards
Heiko1985
- Mute
- Permalink
- Report
Hi Heiko,
I don't use it much but this sounds like a Task Scheduler job to me. Don't know if you ever used this but you can find it under the Windows button > All programs > Autodesk > Inventor "Version" > Tools.
Eelco
- Mute
- Permalink
- Report
Thank you for your help, Eelco.
I took a look at the Task Scheduler but didn’t get along with it at all.
Luckily, I now found a solution myself using iLogic:
Sub update_sheets()
Dim oapp As Inventor.Application
Set oapp = ThisApplication
Dim oDocument As Inventor.Document
Set oDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet
For Each oDocument In oapp.Documents.VisibleDocuments
Name = oDocument.FullDocumentName
For Each oSheet In oDocument.Sheets
' oSheet.Activate
oSheet.Update
Next
oDocument.Save
oDocument.Close
Next
End Sub
