01-29-2015
08:48 PM
- Mute
- Permalink
- Report
01-29-2015
08:48 PM
If you do like to mirror a sketch, maybe you can try a workaround as below:
1. Mirror a WorkPlane for a source sketch you want to mirror it. If the source sketch you want to mirror is based on a planar face then you can create a WorkPlane on the face first.
2. Create a sketch on the mirrored WorkPlane. You may need to change the sketch properties to make it looks like a mirrored sketch of the source sketch.
3. Use PlanarSketch.CopyContentsTo to copy the sketch entities from source sketch to the target sketch.
This will make the taget sketch looks like the mirrored sketch, but the problem is the target sketch could not automatically update when the source sketch has any change. Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
