- Mute
- Permalink
- Report
Adam,
The RunCustomProgram code is called from the Default.ivb file.
This code was posted by someone on this forum a long time ago(couldn't find the post) and I have been using it for about 8 years. It makes adding and distributing VBA macros very easy and works in Inventor 2014. The Default.ivb file is on the network so I can point everyone's Application Options to it.
The issue was that someone else was locking the Default.ivb file through use of a macro even though it wasn't showing as read-only as it typically does. I solved it by having our IT department create a batch file that basically kicks everyone out of the Default.ivb file. You can also do this manually through Windows MMC by Closing Open Files. When everyone is out, I can now edit the file. Thanks for the input.
mr_ensing, thanks for the link. I will check it out.
