Cadmanto
in reply to: zaidi_drafter
Zaidi,
I am not much good at writing iLogic, but as far as implementing the rules, if you copy the rule from your part into the "Edit Rule" dialog
Then just have the iLogic browser open in your regular browser
It will always be there to run in your assembly.  I would setup this arrangement in your part as well as your assembly templates so every new part or assembly model you create will have this there for oyu.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
