YuhanZhang
Unfortunately the APIs for view cube orientation options have not been exposed yet. But I am curiouse about what you said "when creating drawings using topview the result is as if I used frontview.", when you create a drawing view you are able to specify the orientation of model so seems you need not to change the view cube options at all. Can you explain more about what you want to do when create a drawing view?
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
