1048 Views, 4 Replies
change default viewcube orientation through API
Greetings,
I am trying to do what I describe in the title but with no luck.
I am building an assembly from scratch and I want the orientation to be different than the default because when creating drawings using topview the result is as if I used frontview.
I can change the orientation permanently from tools->application options-->display-->viewcube-->default view cube orientation but I would rather do it through the API so that I wouldn't have concerns of what each user has as a preference in his/her PC and after finishing with the assembly I could restore the user's options.
Is there a way?
Thanks in advance!
