447 Views, 4 Replies
Automating derive part
Hi everyone,
I searched the forum and web but couldn't find anything conclusive so guess i had to ask....
Basically i have a standard part (say part_1)and from that part i need to derive another part (part_2) in and then combine & cut part_2 away which leaves me with a cavity in my original part (part_1)
Is there a way of automating this via rules or even vba ?, i've had a little play about with forms etc but i can't seem to get anywhere.
Ideally this would be a option in a form that you'd just pick the part that you wish to derive and the form would work it's magic leaving you with a nice mould at the end.
I think it should be easy enough but i can't seem to crack the case :'-(
Any suggestions chaps ?
p.s im using inventor professional 2015 if it helps?!
Thanks in advance
Regards
Andy
