448 Views, 4 Replies
Automating derive part
Hi everyone,
I searched the forum and web but couldn't find anything conclusive so guess i had to ask....
Basically i have a standard part (say part_1)and from that part i need to derive another part (part_2) in and then combine & cut part_2 away which leaves me with a cavity in my original part (part_1)
Is there a way of automating this via rules or even vba ?, i've had a little play about with forms etc but i can't seem to get anywhere.
Ideally this would be a option in a form that you'd just pick the part that you wish to derive and the form would work it's magic leaving you with a nice mould at the end.
I think it should be easy enough but i can't seem to crack the case :'-(
Any suggestions chaps ?
p.s im using inventor professional 2015 if it helps?!
Thanks in advance
Regards
Andy
VdVeek
Andy, the way you start writing a rule or VBA or Plugin is first you need to find out how you do the tasks manualy. Determine which steps you take when you do it your own, than translate these steps to a rule. Find with each step the equivalent code. Give it a try of your own first. If you still have no idea, maybe somebody can help you furter.
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
Not perfect, but I've been working on similar for a while now.
This is the best I've got.  You have to name your solids appropriately and tailor the options to your liking but this may give you a start.  It goes through a part, finds each solid and cuts out or intersects the interference solid based on which routine you run.  This is all done after you derive a new solid into your part.  It won't help automate deriving the part, just combining afterward.
Option Explicit
Dim oSurfBody As SurfaceBody
Dim oCompDef As ComponentDefinition
Dim oPartCompDef As PartComponentDefinition
Dim oPartDoc As PartDocument
Public Sub DeriveCaution()
    On Error GoTo error_checking
    Dim lngErr As Long
    Dim i As Long
    Dim oSurfBodies As SurfaceBodies
    Set oPartDoc = ThisApplication.ActiveDocument
    Set oPartCompDef = oPartDoc.ComponentDefinition
    Dim oSBInt As SurfaceBody
    Dim oSBCaut As SurfaceBody
    Dim oSBMain As SurfaceBody
    Set oSurfBodies = oPartCompDef.SurfaceBodies
    For Each oSurfBody In oPartCompDef.SurfaceBodies
        If oSurfBody.Name = "Int" Then
            Set oSBInt = oSurfBody
        ElseIf oSurfBody.Name = "Caut" Then
            Set oSBCaut = oSurfBody
        ElseIf oSurfBody.Name = "Main" Then
            Set oSBMain = oSurfBody
        End If
    Next oSurfBody
    Dim test As Long
    oSBInt.Visible = False
    oSBCaut.Visible = False
    oSBMain.Visible = False
    For i = 1 To oPartCompDef.SurfaceBodies.Count
            End If
        Next oSurfBody
        Set oSurfBody = oPartCompDef.SurfaceBodies.Item(i)
        Call IntCombine(oSurfBody, oSBCaut)
    Next i
error_checking:
lngErr = Err.Number
End Sub
Public Sub DeriveInterference()
    Dim lngErr As Long
    Dim i As Long
        If oSurfBody.Name = "INT" Then
        ElseIf oSurfBody.Name = "CAUT" Then
        End If
    Next oSurfBody
    Dim test As Long
            End If
        Next oSurfBody
        Call IntCombine(oSurfBody, oSBInt)
    Next i
error_checking:
lngErr = Err.Number
End Sub
Public Sub DeriveMain()
    Dim lngErr As Long
    Dim i As Long
        End If
    Next oSurfBody
        Call CutCombine(oSurfBody, oSBInt, oSBCaut)
    Next i
error_checking:
lngErr = Err.Number
MsgBox Now
End Sub
Public Sub CutCombine(sbBase As SurfaceBody, ocRemove1 As SurfaceBody, ocRemove2 As SurfaceBody)
    Dim oCombFeat As CombineFeature
    Dim oCombFeats As CombineFeatures
    Dim ocRemove As ObjectCollection
    Dim oTO As TransientObjects
    Set oTO = ThisApplication.TransientObjects
    Set ocRemove = oTO.CreateObjectCollection
    Call ocRemove.Add(ocRemove1)
    Call ocRemove.Add(ocRemove2)
    If Not (sbBase.Name = "INT") And Not (sbBase.Name = "CAUT") _
        And Not (sbBase.Name = "Main") Then
        sbBase.Visible = True
        Set oCombFeats = oPartCompDef.Features.CombineFeatures
        If Not (CombineFeatureExists(sbBase)) Then
            Set oCombFeat = oCombFeats.Add _
                (sbBase, ocRemove, kCutOperation, True)
        End If
    End If
End Sub
Public Sub IntCombine(sbBase As SurfaceBody, sbIntersect As SurfaceBody)
    Call ocRemove.Add(sbIntersect)
              (sbBase, ocRemove, kIntersectOperation, True)
        End If
    End If
End Sub
Private Function CombineFeatureExists(sbCombFeatSB As SurfaceBody) As Boolean
    Dim cfExists As Boolean
    Dim j As Long
    cfExists = False
    For j = 1 To oCombFeats.Count
        If (oCombFeats.Item(j).SurfaceBodies.Item(1).Name = sbCombFeatSB.Name) Then
            cfExists = True
        End If
    Next j
    CombineFeatureExists = cfExists
End Function
Sorry there's no comments, but ask away if you've got a question.
ekinsb
In addition to the sample above, there is also a sample in the API help titled "Derived Parts and Assemblies API Sample".
Brian Ekins
Mod the Machine blog
