12-31-2014
05:05 AM
- Mute
- Permalink
- Report
12-31-2014
05:05 AM
When your rule is executed in the context of the drawing document you are able to get access to all documents that are referenced by your drawing directly or indirectly. Here is the VBA sample that uses ReferencedDocuments and AllReferencedDocuments collections to illustrate the workflow:
Sub Drawing_ReferencedDocs()
'reference to the active drawing document
Dim ThisDoc As Inventor.Document
Set ThisDoc = ThisApplication.ActiveDocument
Dim oDoc As Inventor.Document
Debug.Print "Drawing document: " & ThisDoc.FullFileName
'print all the documents directly referenced by this drawing.
Debug.Print "Referenced documents: (full document names)"
For Each oDoc In ThisDoc.ReferencedDocuments
'Debug.Print oDoc.FullFileName
Debug.Print oDoc.FullDocumentName
Next
Debug.Print
'print all the document references of this drawing
'along with all of the recursively nested references.
Debug.Print "All Referenced documents:"
For Each oDoc In ThisDoc.AllReferencedDocuments
Next
Debug.Print " ----------------- "
Beep
End Sub
You may iterate these collections and save any documents you need. This code should work for assembly document as well.
BTW you may access an assembly or a part document referenced by the specific DrawingView object:
Dim oView As DrawingView Set oView = ThisDoc.Sheets.Item(1).DrawingViews.Item(1) Dim oDiscr As DocumentDescriptor Set oDiscr = oView.ReferencedDocumentDescriptor Debug.Print "Displayname: " & oDiscr.DisplayName Debug.Print "FullDocumentName: " & oDiscr.FullDocumentName Set oDoc = oDiscr.ReferencedDocument Debug.Print "FullFileName: " & oDoc.FullFileName
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
