12-22-2014
07:54 AM
- Mute
- Permalink
- Report
12-22-2014
07:54 AM
ilogic rule to save idw, iam & ipt
'define the active document
oDoc = ThisDoc.Document
'create a file dialog box
Dim oFileDlg As inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
'check file type and set dialog filter
If oDoc.DocumentType = kPartDocumentObject Then
oFileDlg.Filter = "Autodesk Inventor Part Files (*.ipt)|*.ipt"
Else If oDoc.DocumentType = kAssemblyDocumentObject Then
oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam"
Else If oDoc.DocumentType = kDrawingDocumentObject Then
oFileDlg.Filter = "Autodesk Inventor Drawing Files (*.idw)|*.idw"
End If
'set the directory to open the dialog at
oFileDlg.InitialDirectory = ThisDoc.WorkspacePath()
'set the file name string to use in the input box
oFileDlg.FileName = iProperties.Value("Project", "Part Number")
'work with an error created by the user backing out of the save
oFileDlg.CancelError = True
On Error Resume Next
'specify the file dialog as a save dialog (rather than a open dialog)
oFileDlg.ShowSave()
'catch an empty string in the input
If Err.Number <> 0 Then
MessageBox.Show("No File Saved.", "iLogic: Dialog Canceled")
ElseIf oFileDlg.FileName <> "" Then
MyFile = oFileDlg.FileName
'save the file
oDoc.SaveAs(MyFile, False) 'True = Save As Copy & False = Save As
End IfI have a drawing (idw) that I built a ilogic form to drive my assembly (iam). I would like to add a to my ilogic form a option to save. What I really want it to do is to preform a save as of the drawing and then subsequentially save the assembly and one of the parts in the assembly as the same name.
I found peices of code online (and modified to fit) that allows me to get a dialog box and save the drawing but i cannot find a way to drive the save down to the iam and ipt files. I have attached that code to show where I am starting from.
My currect template assembly (iam) file name is 14221214-01 and my part (ipt) is 14221214-02.
