nick.seman
169 Views, 4 Replies
Modifying an existing sketch arc using VBA
I have the need to update an existing sketch arc via VBA.  I cannot delete and replace it as I have downstream dependencies.  I am almost able to accomplish it by constraining the start, center, and end points to sketch points (based on work points) and then programmatically modifying the locations of the work points - which works except when the curve direction of the arc (left or right) flips.
While I am able to harvest all the information about the existing arc using "SketchArc" I do not see any way to update the definition.
Can anyone provide any ideas or direction on this?
Thanks;
Nickl
