william
in reply to: drafter_sby2
Have you unzipped the .ini file and set the correct path in the rule to find it?
Dim strIniFile As String
strIniFile = "C:\path to export file\ExportDWG.ini"
Beyond that, I'm not sure what to suggest. It is strange that you are getting errors from line 1 onwards.
Can you open the ilogic rule in the editor and send a screenshot through?
