drafter_sby2
160 Views, 3 Replies
Export Drawing File to Dxf
Hi All,.. I create a Code For External Rule In *.dwg File.
my case like this:
1. I have a Drawing file in autodesk inventor.
2. I want to create an external rule which will export the active sheet into a Dwg file with a ratio of 1: 1 Autocad File 2010
3. The location for storing the Dwg file is placed in the active document in a folder called "01.Data"
4. Name the file according to the name of the active sheet.
 did anyone Have some reference?
Tags (1)
Labels (2)
william
in reply to: drafter_sby2
Something like this?
Imports System.IO.Path
Imports System.IO
Imports System.Collections
Imports System.Windows.Forms
'Check it is an .idw
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
    MessageBox.Show("This is not a drawing. This rule can only be run in an .idw environment" & vbNewLine & "The rule will exit...", "Error Handling",MessageBoxButtons.OK,MessageBoxIcon.Error)
    Return
End If
' Check that this file has been saved and actually exists on disk
If String.IsNullOrEmpty(ThisDoc.Path) Then
    MessageBox.Show("This file has not yet been saved and doesn't exist on disk!" & vbLf & "Please save it first","Error Handling",MessageBoxButtons.OK,MessageBoxIcon.Error)
	Return
End If
strPath_Original = ThisDoc.Path
strExportPath = ThisDoc.Path & "\01.Data\"
If System.IO.Directory.Exists(strExportPath) = False Then
	System.IO.Directory.CreateDirectory(strExportPath)
End If
Dim strIniFile As String
strIniFile = "C:\path to export file\ExportDWG.ini"
'Check that the export configuration file is downloaded
If System.IO.File.Exists(strIniFile) = False Then
	MessageBox.Show("Cannot find the export configuration file: " & vbNewLine & strIniFile & vbNewLine & "The rule will exit...", "Error Handling", MessageBoxButtons.OK, MessageBoxIcon.Error)
	Return
End If
Dim oDDoc As DrawingDocument = ThisDrawing.Document
i = 0
For Each S As Sheet In oDDoc.Sheets
	i += 1
	If S Is oDDoc.ActiveSheet Then
		ExportFilename = strExportPath & "Sheet " & i & "_DWG 2D.dwg"
	End If
Next
' Get the DWG translator Add-In
Dim DXFAddIn As TranslatorAddIn
DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
Dim oDocument As Document
oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
oOptions.Value("Export_Acad_IniFile") = strIniFile
End If
'Set the DXF target file name
oDataMedium.FileName = ExportPath & ExportFilename
MessageBox.Show(oDataMedium.FileName, "Filename")
Try
	'Publish document
	DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Catch
	MessageBox.Show("Error writing out DWG", "Error Handling",MessageBoxButtons.OK,MessageBoxIcon.Error)
End Try
Export file attached, just unzip and put it somewhere with your system files.
drafter_sby2
hai @william  ,. yes u are right.  but The location for storing the Dwg file is placed in the active document in a folder called "01. Data" (example name) this possible to do?
Because of many problem in me. for your code to run.
william
Have you unzipped the .ini file and set the correct path in the rule to find it?
Beyond that, I'm not sure what to suggest. It is strange that you are getting errors from line 1 onwards.
Can you open the ilogic rule in the editor and send a screenshot through?
