Dai_Tech
169 Views, 3 Replies
How to Export BOM Rows in Structured Order Based on Item Number?
Hello everyone,
I am trying to export the rows of a Structured BOM from Autodesk Inventor in the order of Item Number that I have already configured in the BOM. However, when I run my code, the rows do not export in the expected order.
Here is my code:
Sub Main
	Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
    Dim oBOM As BOM = oAsmDoc.ComponentDefinition.BOM
    oBOM.StructuredViewEnabled = True
    Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured")
	Call QueryBOM(oBOMView.BOMRows)
End Sub
Public Sub QueryBOM(oBOMRows As BOMRowsEnumerator)
	Static CurrenrRow As Integer = 3
	Dim i As Integer
	For i = 1 To oBOMRows.Count
		Dim oRow As BOMRow = oBOMRows.Item(i)
		Dim oCompDef As ComponentDefinition = oRow.ComponentDefinitions.Item(1)
		 MsgBox(oRow.ItemNumber & "_" & System.IO.Path.GetFileName(oCompDef.Document.FullFileName))
		If Not oRow.ChildRows Is Nothing Then
			Call QueryBOM(oRow.ChildRows)
		End If
	Next
End Sub
