- Mute
- Permalink
- Report
How to Export BOM Rows in Structured Order Based on Item Number?
Hello everyone,
I am trying to export the rows of a Structured BOM from Autodesk Inventor in the order of Item Number that I have already configured in the BOM. However, when I run my code, the rows do not export in the expected order.
Here is my code:
Sub Main
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oBOM As BOM = oAsmDoc.ComponentDefinition.BOM
oBOM.StructuredViewEnabled = True
Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured")
Call QueryBOM(oBOMView.BOMRows)
End Sub
Public Sub QueryBOM(oBOMRows As BOMRowsEnumerator)
Static CurrenrRow As Integer = 3
Dim i As Integer
For i = 1 To oBOMRows.Count
Dim oRow As BOMRow = oBOMRows.Item(i)
Dim oCompDef As ComponentDefinition = oRow.ComponentDefinitions.Item(1)
MsgBox(oRow.ItemNumber & "_" & System.IO.Path.GetFileName(oCompDef.Document.FullFileName))
If Not oRow.ChildRows Is Nothing Then
Call QueryBOM(oRow.ChildRows)
End If
Next
End Sub
- Mute
- Permalink
- Report
Does your Top Assy BOM always reflect the correct order of the BOM Rows?
As oftentimes the sorting of the ChildRows from Top Assy BOM Rows is not the same with the how it is sorted in the Sub-Assy BOM.
Below code is a modified one where you use the Sub-Assy BOM for the order of the item number.
Sub Main
Call QueryBOM(oBOM, "")
End Sub
Public Sub QueryBOM(oBOM As BOM, TabSpace As String)
oBOM.StructuredViewFirstLevelOnly = False
Dim oBOMRows As BOMRowsEnumerator = oBOMView.BOMRows
Dim i As Integer
'MsgBox(oRow.ItemNumber & "_" & System.IO.Path.GetFileName(oCompDef.Document.FullFileName))
Logger.Info(TabSpace & oRow.ItemNumber & "_" & System.IO.Path.GetFileName(oCompDef.Document.FullFileName))
Dim oChildAsm As AssemblyDocument = oRow.ComponentDefinitions(1).Document
Call QueryBOM(oChildAsm.ComponentDefinition.BOM, TabSpace & " ")
End If
Next
End Sub
Or if you opt to use how the ChildRows's Item Numbers, I have used a SortedDictionary object as intermediary.
Probably not the best way, but a possible workaround.
Sub Main
Call QueryBOM(oBOMView.BOMRows, "")
End Sub
Public Sub QueryBOM(oBOMRows As BOMRowsEnumerator, TabSpace As String)
Dim oBOMROW_Dict As New SortedDictionary(Of String, BOMRow)
For Each oBOMRow As BOMRow In oBOMRows
If Not oBOMROW_Dict.ContainsKey(oBOMRow.ItemNumber) Then
oBOMROW_Dict.Add(oBOMRow.ItemNumber,oBOMRow)
End If
Next
'Dim i As Integer
For Each key In oBOMROW_Dict
'For Each oRow As BOMRow In oBOMRows
Dim oRow As BOMRow = key.Value
Call QueryBOM(oRow.ChildRows, TabSpace & " ")
End If
Next
End Sub
- Mute
- Permalink
- Report
Thank you, sir, nice idea!!! However, your code has an issue with the "SortedDictionary function" (e.g., 2.1 -> 2.10 results in: 2.1, 2.10, 2.2, 2.3...2.9). But I've fixed it already. Thank you so much!
Fixed
