@PolemEngineering
Maybe you could:
  • create an external rule that sets the variables
  • and then  create a module in Visual Studio to call the rule
  • and then add a line in the StandardAddinServer to call the module in Visual Studio that runs the rule
This line is in your StandardAddInServer:
Run_External_iLogic_Rule.RunExternalRule("My External Rule To Set Shared Variables")
This would be the module in Visual Studio that calls external rules by name:
Imports Inventor
Module Run_External_iLogic_Rule
    Public Sub RunExternalRule(ByVal ExternalRuleName As String)
        Try
            ' The application object.
            Dim addIns As ApplicationAddIns = g_inventorApplication.ApplicationAddIns()
            ' Unique ID code for iLogic Addin
            Dim iLogicAddIn As ApplicationAddIn = addIns.ItemById("{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}")
            ' Starts the process
            iLogicAddIn.Activate()
            ' Executes the rule
            iLogicAddIn.Automation.RunExternalRule(g_inventorApplication.ActiveDocument, ExternalRuleName)
        Catch ex As Exception
            MsgBox("Error launching external rule: " & vbLf & "     " & ExternalRuleName _
                   & vbLf & vbLf & "Ensure the iLogic rule exists, and that the" _
                   & vbLf & "configuration includes the path to the rules." _
                   & vbLf & vbLf & "see Tools tab > Options flyout button > iLogic Configuration button" _
                   & vbLf & "    If needed, add an external rules folder path," _
                   & vbLf & "    and ensure that the rule is found in this folder.")
            Return
        End Try
    End Sub
End Module
Something like this would be the external rule:
SharedVariable("Test Variable 01") = "hello"
SharedVariable("Test Variable 02") = "world"
