Just as a test you could change the function StandardAddInServer.Automation(...) in your addin to something like this:
    Public ReadOnly Property Automation As Object Implements ApplicationAddInServer.Automation
        Get
		If Not (_myVariableObjectIs Nothing) Then
			MsgBox(_myVariableObject.MyVariable)
		Else
			MsgBox("Apparently the object remains Nothing")
		End If
        	Return _myVariableObject
        End Get
    End Property
Now run your iLogic code. You should get a messagebox from your addin.
If your variable _myVariableObject is here also nothing then I expect that there is something wrong in the function StandardAddInServer.Activate(...) In my previous example I set the values on lines 8 and 9
Jelte de Jong
Blog: hjalte.nl - github.com
