- Mute
- Permalink
- Report
I did, but I can't seem to get the right stuff together to make it work.
It is with the ISharedVariable interface. In the Object Browser is mentioned that, in a rule, this interface is implemented by the predefined object named SharedVariable. That's also how I use it in regular iLogic-rules. In Jelte's blog is mentioned that the AbstractRule-class currently contains 2 properties.
So I tried to add "Public Property SharedVariable As ISharedVariable" and in another attempt "Public SharedVariable As ISharedVariable"
But I keep getting te error "Object reference not set to an instance of an object." when running something simple as this:
Try
SharedVariable.Value("TestVariable") = "TestValue"
Catch ex As Exception
MessageBox.Show(ex.Message, "Attempt to create SharedVariable 'TestVariable' with value 'TestValue'")
End TryCould makes sense, because I don't do anything with the previously declared and assigned iLogicAutomation object.
As an alternative I now try to just notice the events and then trigger an external rule. I don't know yet if this will work. iLogic is only available from the Inventor interface when/after opening a document. For that reason I also check if the Automation is activated. Otherwise .activate()
Things remain confusing and I'm afraid I'm on the wrong track.
Btw, I run Inventor 2023.5.1
René van der Starre
