11-21-2024
06:22 AM
- Mute
- Permalink
- Report
11-21-2024
06:22 AM
Thank you for your help and response! After all the efforts, I was able to get it working exactly as I originally intended—directly from the top-level assembly.
The main key was to store the entire hierarchical path to the occurrence and then use that same path later when modifying its transparency. This ensured precise targeting of individual parts, even within complex subassembly structures.
Below is a sample iLogic code that sets any selected (or previously stored list of parts in my case) to transparent mode.
I hope this solution helps others facing a similar challenge! Let me know if further clarification is needed.
Sub Main() ' Get the active document (assumes an assembly is open) Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument ' Get the current selection set Dim oSelSet As Inventor.SelectSet = oDoc.SelectSet ' Check if any component is selected If oSelSet.Count = 0 Then MessageBox.Show("No component selected. Please select a component.", "Error") Return End If ' Initialize a variable for the selected component occurrence Dim oSelectedOccurrence As ComponentOccurrence = Nothing ' Loop through the selection set to find a ComponentOccurrence For Each oSelObj In oSelSet If TypeOf oSelObj Is ComponentOccurrence Then oSelectedOccurrence = oSelObj Exit For End If Next ' If no valid component is selected, show an error If oSelectedOccurrence Is Nothing Then MessageBox.Show("The selected item is not a valid component occurrence.", "Error") Return End If ' Prepare to store hierarchy information Dim hierarchyInfo As New System.Text.StringBuilder() Dim fullHierarchyID As New System.Text.StringBuilder() ' Process the selected component and its parent hierarchy Dim currentOccurrence As ComponentOccurrence = oSelectedOccurrence Dim level As Integer = 0 Do While Not currentOccurrence Is Nothing ' Indent based on the hierarchy level Dim indentation As String = New String(" "c, level * 4) ' 4 spaces per level ' Get the occurrence ID Dim occurrenceID As String = currentOccurrence.Name ' Occurrence ID ' Add the occurrence ID to the hierarchy info hierarchyInfo.Insert(0, indentation & occurrenceID & vbNewLine) ' Build the full hierarchy path (using ~ as a separator for easier processing) fullHierarchyID.Insert(0, currentOccurrence.Name & "~") ' Move to the parent occurrence currentOccurrence = currentOccurrence.ParentOccurrence level += 1 Loop ' Remove the trailing ~ from the full hierarchy ID If fullHierarchyID.Length > 0 Then fullHierarchyID.Length -= 1 End If ' Set the selected part to transparent Try oSelectedOccurrence.Transparent = True MessageBox.Show("Selected part has been set to transparent." & vbNewLine & "Hierarchy:" & vbNewLine & hierarchyInfo.ToString() & vbNewLine & "Full Occurrence ID Path: " & fullHierarchyID.ToString(), "Transparency Set") Catch ex As Exception MessageBox.Show("Failed to set transparency: " & ex.Message, "Error") End Try End Sub
