WCrihfield
in reply to: mitoborecek
Hi @mitoborecek.
You did not really answer any of the 3 questions I asked you.
  1. Do you have any lines of code within any of those iLogic rules that you mentioned that are for updating the assembly after changes have been made?
  2. After you run the rules, but before you try to drag & drop anything, have you tried just clicking on the Update button (Manage tab > Update panel), to see if that will cause the components to move to their correct positions?
    1. If you have tried that, then what was the result?  Did they move to correct locations, or did they stay in wrong locations?
    2. If the Update button did not work, then have you tried using the Rebuild All button, to see if that will cause them to move to their correct positions?
      1. If you tried using the Rebuild All button, then what was the result...did it work, nor not?
  3. Do you have your settings set to 'Defer Updates'?
    1. That setting can be found manually in the Application Options, on the Assembly tab, the top option.
Knowing the answers to those questions may help us understand what is going on, so that we can help you fix the problem.
Wesley Crihfield
(Not an Autodesk Employee)
