The problem is in the iLogic named "UpdateDrwRecources".
The rule basically deletes all drawing recourses and afterward adds/replaces them by the ones from the drawing template.
When the rule is executed from the add-inn the deleting of existing borders (for example) is not working.
This screenshot shows the add-inn to execute the ilogic "Start"
When I outcomment the last step of the iLogic "UpdateDrwRecources" in which new drawing recources are added, I can see that the deleting is not happening, if the rule is executed initially by the add-inn (via ilogic Start in between):
(the rule itself is running if executed by add-inn, I could check that with message boxes)
sorry for the messy code:
Sub main
'List of Variables
	Dim oDrawingDoc As Inventor.DrawingDocument
    Dim oSheetNumber As Integer
	Dim oActiveSheetNumber As Integer
	Dim oActiveSheetName As String
	Dim oSheet As Sheet
    Dim oSourceTitleBlockDef As TitleBlockDefinition
    Dim oNewTitleBlockDef As TitleBlockDefinition
	Dim oBorderName As String
'Selects this document
	'oDrawingDoc = ThisApplication.ActiveDocument
	oDrawingDoc = ThisDoc.Document
'Checks if there is a Title Block on the Active Sheet
        If oDrawingDoc.ActiveSheet.TitleBlock Is Nothing Then
		MessageBox.Show ("Please Insert a Title Block on this Sheet!")
		Exit Sub
        End If
'Gets the Name of the Active Sheet to Activate it at the end of the Code
	oActiveSheetName = ActiveSheet.Name
'Gets the Name of the Title Block Currently in the Drawing to Insert at the end of this code
    oSheet = oDrawingDoc.ActiveSheet
    If (oSheet.TitleBlock.Name = "company_name Title block") Then
        oTitleBlockName = "company_name Title block"
	 Else:
        MessageBox.Show ("This drawing has an unknown title block")
        Exit Sub
    End If
'Gets the Name of the Border Currently in the Drawing to Insert at the end of this code
Try
	 oBorderName = oSheet.Border.Name
Catch
	MessageBox.Show("No border exists", "Title")
	Exit Sub
End Try
'Deletes ALL of the Title Blocks Shown in the Drawing
For oSheetNumber = 1 To oDrawingDoc.Sheets.Count
        oDrawingDoc.Sheets(oSheetNumber).Activate
        If Not oDrawingDoc.ActiveSheet.TitleBlock Is Nothing Then
            oDrawingDoc.ActiveSheet.TitleBlock.Delete
        End If
    Next oSheetNumber
	'MessageBox.Show (oActiveSheetName & vbCr & oTitleBlockName)
	Dim oTitle As TitleBlockDefinition
	Dim oTitleBlock As TitleBlock
	For Each oTitle In oDrawingDoc.TitleBlockDefinitions
        If oTitle.IsReferenced = False Then
        oTitle.Delete
        End If
		Next
'Deletes ALL of the Borders Shown in the Drawing
        If Not oDrawingDoc.ActiveSheet.Border Is Nothing Then
            oDrawingDoc.ActiveSheet.Border.Delete
        End If
    Next oSheetNumber
'Clear drawing resources
If oCurrentPane = "Vault" Then
ThisApplication.ActiveDocument.BrowserPanes.Item("Model").Activate
End If
	'delete sheet formats
	Dim oDoc As DrawingDocument
	oDoc = ThisApplication.ActiveEditDocument
	Dim oPane As BrowserPane
	oPane = oDoc.BrowserPanes.ActivePane
	Dim oDocNode As BrowserNode
	oDocNode = oPane.TopNode
	Dim oDrawingResourceNode As BrowserNode
	oDrawingResourceNode = oDocNode.BrowserNodes.Item("Drawing Resources")
	Dim oTitleBlocksNode As BrowserNode
	oTitleBlocksNode = oDrawingResourceNode.BrowserNodes.Item("Sheet Formats")
	Dim oBordersNode As BrowserNode
	oBordersNode = oDrawingResourceNode.BrowserNodes.Item("Borders")
	Dim oTitleBlocks As BrowserNode
	oTitleBlocks = oDrawingResourceNode.BrowserNodes.Item("Title Blocks")
	Dim oNode As BrowserNode
	For Each oNode In oTitleBlocksNode.BrowserNodes'oDocNode.BrowserNodes
	' If the node is visible and expanded, collapse it.
	If oNode.Visible = True And oNode.Expanded = False Then
	oNode.Expanded = True
	End If
	Next
	For Each oNode In oBordersNode.BrowserNodes'oDocNode.BrowserNodes
	End If
	Next
	For Each oNode In oTitleBlocks.BrowserNodes'oDocNode.BrowserNodes
	End If
	Next
	Dim oSheetFormatNode As BrowserNode
	For Each oSheetFormatNode In oTitleBlocksNode.BrowserNodes
	' Select the node in the browser.
	oSheetFormatNode.DoSelect
	' Execute the delete command.
	ThisApplication.CommandManager.ControlDefinitions.Item("AppDeleteCmd").Execute
	Next
	'Dim oBordersNode As BrowserNode
	For Each oBordersNode In oBordersNode.BrowserNodes
	oBordersNode.DoSelect
	Next
	For Each oTitleBlocks In oTitleBlocks.BrowserNodes
	oTitleBlocks.DoSelect
	Next
'Adds the Title Blocks from the Template File
ThisDrawing.ResourceFileName = "C:\WS_company_name\Templates\Standard.idw"
ThisDrawing.KeepExtraResources = True
'ActiveSheet.TitleBlock = "company_name Title block"
'ActiveSheet.Border = oBorderName
'Add Borders
ActiveSheet.Border = "A1"
ActiveSheet.Border = "A2"
ActiveSheet.Border = "A3"
ActiveSheet.Border = "A4"
ActiveSheet.Border = "A0"
''Adds the Same Title Block as in the initial drawing
''due to the fact that we use different title blocks for different sub-companies we do not bring in the title block from the template anymore
	ActiveSheet.TitleBlock = oTitleBlockName
    Next oSheetNumber
'MsgBox(oBorderName)
''Activates the Sheet by Full Name
ActiveSheet = ThisDrawing.Sheet(oActiveSheetName)
'MsgBox("test: rule UpdateDrwRecources is executed now")
End Sub
I cannot figure out if there is a limitation to execute the delete command
	Next
or if my code is not clear enough and it is unclear in which document the deleting should happen.
As I said, when the iLogic "Start" and through that the iLogic "UpdateDrwRecources" is run manually everything is working.
Do you have an advice for me?
