WCrihfield
in reply to: mitoborecek
Hi @mitoborecek.  Do you have any lines of code in your iLogic rules that will update the assembly after changes have been made?  If you click the update button after you rules have finished running, but before the 'click in space or drag and drop', to see if that makes the components move to their proper positions.  Do you have your settings set to 'Defer Updates'?  (Application Options > Assembly tab > top option)
Wesley Crihfield
(Not an Autodesk Employee)
