11-13-2024
01:22 AM
- Mute
- Permalink
- Report
11-13-2024
01:22 AM
This is a sample, how to create drawing dimension to the specified edge in model. It requires update, because it doesn't contain your logic for edge selection, text positioning, works only for part, etc. But it can be used as starting point.
Expected dataset:
- Drawing with single drawing view on active sheet
- Drawing view references simple part with one extrusion of box
'Get relevant documents
dim drw as DrawingDocument = ThisDoc.Document
dim part As PartDocument = drw.ReferencedDocuments(1)
'Get edge in model
' !! This is just a sample. Modify it for your needs. !!
Dim partEdge = part.ComponentDefinition.Features.ExtrudeFeatures(1).EndFaces(1).Edges(1)
'Get drawing sheet and view
Dim drwSheet as Sheet = drw.ActiveSheet
Dim drwView as DrawingView = drwSheet.DrawingViews(1)
'Get drawing curve which corresponds with model edge
Dim edgeCurves As DrawingCurvesEnumerator = drwView.DrawingCurves(partEdge)
If edgeCurves.Count = 0 Then
Logger.Error("There is no drawing curve for specified edge.")
return
End If
'Create geometry intent for edge
Dim partEdgeIntent As GeometryIntent = drwSheet.CreateGeometryIntent(edgeCurves(1))
'Crete dimension
Dim textOrigin As Point2d = drwView.Position
drwSheet.DrawingDimensions.GeneralDimensions.AddLinear(textOrigin, partEdgeIntent, DimensionType := DimensionTypeEnum.kAlignedDimensionType)
Dataset preview
