WCrihfield
in reply to: 442780782
Hi @442780782.  That overall code example above does not really appear to be document type specific.  But the task it is doing could be done in a simpler way, using much less code.  What are you currently trying to do?
If the title of this topic is what caught your attention, then you may like the following vb.net code property:
Microsoft.VisualBasic.FileIO.FileSystem.CurrentDirectory
It is a Read/Write property with a String type value representing a system-wide environment variable.
Also, in the Inventor API, we have this method that we can use for 'posting' things like file names, Strings, Booleans, and such to accompany command execution calls.
CommandManager.PostPrivateEvent (ThisApplication.CommandManager.PostPrivateEvent)
It will post (or send) some data up into Inventor's session memory, similar to the clipboard method being used in the example above, but scoped to Inventor's internal clipboard, instead of the whole operating system's clipboard.  It has a companion method also, for clearing such data, when needed.
CommandManager.ClearPrivateEvents
Wesley Crihfield
(Not an Autodesk Employee)
