Hi @d_stapleton,
I share you the information about AddReference: LINK to documentation
I think it only supports .dll files , that might be what you’re experiencing. Maybe you need to copy the dll file of the AddReference in C:\Program Files\Autodesk\Inventor [Version]\Bin\iLogicAdd.
I've struggled with iLogic many times as well. I believe an Add-In workflow is better for these tasks, as the Visual Studio IDE doesn’t have issues like the one you're facing.
Regards.
Sergi Casado.
Please mark a "Solution as solved" when the issue is solved ! And a Like if it helps you.
