jjstr8
in reply to: bindlmi
It's under InventorApplication.CommandManager.ControlDefinitions["command name"].Enabled. InventorApplication is your field/property for the Application object. The command name is the internal name you used in AddButtonDefinition. Here's a C# example. This goes in your ApplicationAddinServer implementation.
private void UserInterfaceEvents_OnEnvironmentChange(Inventor.Environment environment, EnvironmentStateEnum environmentState, EventTimingEnum beforeOrAfter, NameValueMap context, out HandlingCodeEnum handlingCode)
    if ((environmentState == EnvironmentStateEnum.kActivateEnvironmentState || environmentState == EnvironmentStateEnum.kResumeEnvironmentState) && beforeOrAfter == EventTimingEnum.kAfter)
        switch (environment.InternalName)
            case "AMxAssemblyEnvironment":
            case "AMxWeldmentEnvironment":
                InventorApplication.CommandManager.ControlDefinitions["myAddin:myAssemblyCmdBtn"].Enabled = true;
                InventorApplication.CommandManager.ControlDefinitions["myAddin:myPartCmdBtn"].Enabled = false;
                break;
            case "PMxPartEnvironment":
            case "MBxSheetMetalEnvironment":
                InventorApplication.CommandManager.ControlDefinitions["myAddin:myAssemblyCmdBtn"].Enabled = false;
                InventorApplication.CommandManager.ControlDefinitions["myAddin:myPartCmdBtn"].Enabled = true;
                break;
            case "FWxMainFrameEnvironment":
            case "DLxDrawingEnvironment":
            case "DXxPresentationEnvironment":
            default:
    handlingCode = HandlingCodeEnum.kEventNotHandled;
