C_Haines_ENG
159 Views, 4 Replies
EventHandlers Glitching Inventor - Cant Edit Sketches / Open Components
Good Morning everyone,
I have actually had this issue for quite a while, but Interaction events / Event Handles are causing my Inventor to stop functioning properly. See my code below:
Sub Main
	Dim oAsm As AssemblyDocument = ThisDoc.Document
	Dim oSelect As New oSelectClass
	oSelect.Pick(ThisApplication)
	If oSelect.oFrame Is Nothing Then Exit Sub
	Logger.Info(oSelect.oFrame.Name)
	Logger.Info(oSelect.oModelPoint.X)
End Sub
Class oSelectClass
	Private WithEvents oInteractEvents As InteractionEvents
	Private WithEvents oSelectEvents As SelectEvents
	Public oFrame As ComponentOccurrence
	Public oModelPoint As Point
	Public Sub Pick(oApp As Inventor.Application)
		oInteractEvents = oApp.CommandManager.CreateInteractionEvents
		oInteractEvents.StatusBarText = "SELECT FRAME, ESC TO EXIT"
		oSelectEvents = oInteractEvents.SelectEvents
		oSelectEvents.AddSelectionFilter(kAssemblyLeafOccurrenceFilter)
		oInteractEvents.Start() : AppActivate(oApp.Caption)
		Do While oFrame Is Nothing
			oApp.UserInterfaceManager.DoEvents
		Loop
		oInteractEvents.Stop : oApp.CommandManager.StopActiveCommand
		oSelectEvents = Nothing : oInteractEvents = Nothing
	End Sub
	Private Sub oSelectEvents_OnSelect(oFrames, oDevice, oPoint, oView2D, oView) Handles oSelectEvents.OnSelect
		oFrame = oFrames(1)
		oModelPoint = oPoint
	End Sub
End Class
 I suspect it has something to do with Interaction events not actually "stopping" when using InteractionEvents.Stop. It causes other interaction events such as editing a sketch to not allow you to change anything, and having the "save sketch" feature greyed out, or being unable to select a component occurrence to open it individually.
If anyone knows anything about this and could fix my nightmare, that would be appreciated.  While "oApp.CommandManager.StopActiveCommand" does exit you out, it seems to have more consequences than I thought.
To test this issue, simply run the command a few times, maybe click on items in an assembly. Then try to edit a sketch and see how it doesn't work anymore! This could also have something to do with loops but I doubt it.
