bdeslippe
145 Views, 2 Replies
Part Hole Tolerance Precision
Hello All,
Is there a way, via iLogic or with the API, to set the precision of a specific hole's tolerance? I have set the tolerance type like this:
holeFeature.HoleDiameter.Tolerance.SetToFits(ToleranceTypeEnum.kLimitsFitsShowTolerance, fastenerType, "");
But I am not able to set the precision to X.XXX decimal places like you can in the UI. Any suggestions?
Michael.Navara
in reply to: bdeslippe
Property holeFeature.HoleDiameter returns Parameter object. See its Parameter.Precision property. It should be what are you looking for.
bdeslippe
in reply to: Michael.Navara
Sweet and simple. Can't believe I missed that.
Thank you very much!
