WCrihfield
in reply to: josh.nieman
Likely the 3 least expected are while working on a weldment type assembly, because there are so few code examples of doing those types of things here in this forum.  Generally, when you have a weldment type assembly open, but are are not yet in any specific 'edit mode', you just get something very generic, and useless like "_DocumentClass".  But then there are the "Welds", Machining", and "Preparations".  Each of those sub environments can actually be activated by code also, when starting from the WeldmentComponentDefinition.
Welds.Edit
Machining.Edit
Preparations.Edit
Wesley Crihfield
(Not an Autodesk Employee)
