WCrihfield
in reply to: e_jeanUH6EY
OK.  Then, are you saying that you are not exporting a 'true' FlatPattern object, but just a flat part from the 'folded model' mode, that simply does not have any bends or flanges in it yet?  It took me a while to create an alternate code example that you can review, but when I typed this up, I had a regular FlatPattern object in mind, not just a regular part with no bends or folds in it yet.
Sub Main
	oInvApp = ThisApplication
	sPrimaryMSName = oInvApp.LanguageTools.CurrentPrimaryModelStateString
	Dim oDoc As Inventor.Document = ThisDoc.Document
	Dim sMainDWG As String = System.IO.Path.ChangeExtension(oDoc.FullFileName, ".dwg")
	ExportFlatPatternToDWG(oDoc, sMainDWG)
	For Each oRefDoc As Inventor.Document In oDoc.AllReferencedDocuments
		Dim sRefDWG As String = System.IO.Path.ChangeExtension(oRefDoc.FullFileName, ".dwg")
		ExportFlatPatternToDWG(oRefDoc, sRefDWG)
	Next oRefDoc
End Sub
Dim oInvApp As Inventor.Application
Dim sPrimaryMSName As String
Sub ExportFlatPatternToDWG(oDoc As Inventor.Document, sDWG_FullFileName As String)
	If (oDoc Is Nothing) OrElse (Not TypeOf oDoc Is PartDocument) Then Return
	Dim oPDoc As PartDocument = oDoc
	If (Not TypeOf oPDoc.ComponentDefinition Is SheetMetalComponentDefinition) Then Return
	Dim sMS_Name As String = oPDoc.ModelStateName
	If (Not String.IsNullOrEmpty(sMS_Name)) AndAlso (sMS_Name <> sPrimaryMSName) Then
		Dim sFDN As String = oInvApp.FileManager.GetFullDocumentName(oPDoc.FullFileName, sPrimaryMSName)
		oPDoc = oInvApp.Documents.Open(sFDN, False)
	End If
	Dim oSMDef As SheetMetalComponentDefinition = oPDoc.ComponentDefinition
	Dim oFP As FlatPattern = Nothing
	If oSMDef.HasFlatPattern Then
		oFP = oSMDef.FlatPattern
	Else
		Try
			oSMDef.Unfold
			oFP.ExitEdit
		Catch
		End Try
	End If
	If oFP Is Nothing Then Return
	'<<< CHANGE THIS FORMAT STRING AS NEEDED >>>
	Dim sFormat As String = "FLAT PATTERN DWG?AcadVersion=2004&Outerprofilelayer=0&Interiorprofileslayer=0&BendLayer=6&BendDownLayer=6&InvisibleLayers=IV_TANGENT;IV_ARC_CENTERS;IV_FEATURE_PROFILES;IV_BEND;IV_BEND_DOWN;IV_FEATURE_PROFILES_DOWN&MergeProfilesIntoPolyline=TRUE&SimplifySplines=TRUE&REBASEGEOMETRY=TRUE"
	'&BendLayer=SCRIBE&BendDownLayer=SCRIBE
	Try
		oFP.DataIO.WriteDataToFile(sFormat, sDWG_FullFileName)
		Logger.Error("Following DWG Was Created:" & vbCrLf & oPDoc.sDWG_FullFileName)
	Catch
		Logger.Error("Error Exporting Following Part To DWG!" _
		& vbCrLf & oPDoc.FullDocumentName)
	End Try
End Sub
But if we are just exporting the regular part, we can use a slightly simpler version of practically the same code.
Sub Main
	Next oRefDoc
End Sub
	End If
	Try
		oSMDef.DataIO.WriteDataToFile(sFormat, sDWG_FullFileName)
	Catch
	End Try
End Sub
Both of these examples can be ran from any type of document.  If the current document is a sheet metal part, it will attempt to export it to DWG.  If it is an assembly or drawing, those usually have referenced documents, and it will iterate through those, and attempt to export any sheet metal parts it finds to DWG.  I copied the 'Format' String from your attached code, so I hope that is OK.  It is just saving those DWG files in the same location as the part file, and with the same name as the part file, so you may have to change that, if needed.  But this is just example code for review and testing.  You can change it however you want, or copy parts of it out into your other code, if you want.
Wesley Crihfield
(Not an Autodesk Employee)
