ambrosiPZ23D
255 Views, 7 Replies
Changing lenght pipe in content centre
Hello everyone,
I have a problem for some pipe families in CC about changing the lenght.
As you could see in the picture, Inventor propose to me 1mm, but the pipe in the file are 150mm.
If I change the value (e.g. 200mm) and retry, again in the lenght filed I find 1mm.
Always the 3d model is correct.
Could you help me?
jnowel
in reply to: ambrosiPZ23D
It seems like the Length parameter (in the Content Center Family Properties) is not linked with the model parameter.
Search “Edit Family Properties” in the following link:
How to Add Properties and Parameters to Content Center Families (ketiv.com)
ambrosiPZ23D
Thanks for your help.
It looks like linked:
jnowel
Check which parameter is being used to drive the model length (extrude feature?)
ambrosiPZ23D
It seems ok.
L  lenght of extrusion.
jnowel
at a glance, it should work.
Are you able to share a video showing the odd behavior?
ambrosiPZ23D
Here we go.
jnowel
I think i managed to replicate that behavior.
the issue seems to be at the Family Table, where PL is assigned to the Custom.PL iproperty.
if you can remove that.
and just redefine your template to have the Parameter PL exported to iproperties
