10-02-2024
02:26 AM
- Mute
- Permalink
- Report
10-02-2024
02:26 AM
Morning,
We use part templates for some commonly used parts. When opened these templates open a form where you can edit specific parameters of the part.
Eg. When the nameplate template is opened, a form opened and you are able to edit the information on the nameplate.
Currently the model will update after every change made within the form, which takes a long time since the info text is embossed for drawing visibility.
Is it possible to configure the form to update the model only once the Done button is pressed?
10-02-2024
03:08 AM
- Mute
- Permalink
- Report
10-02-2024
03:08 AM
Hi!
Yes is possible.
Use the "OK CANCEL APPLY" mode.
You can change some options in the form, but the rules only start after you do APPLY (or OK to apply and close the form).
CCarreiras
10-02-2024
03:11 AM
- Mute
- Permalink
- Report
10-02-2024
03:15 AM
- Mute
- Permalink
- Report
