10-01-2024
10:46 AM
- Mute
- Permalink
- Report
10-01-2024
10:46 AM
I wrote something up that's much more direct in how to do something like you asked. Note, this has not been tested but it shows the exact logic I'd use in two different ways to solve this problem. I noticed some missing or weird overlaps between the drawing sheet size and paper size. These might need to be accounted for in multiple ways. That is you may not be able to use a single method in this pasted code. It may require more than one.
Lastly, I would move the selections into a sub routine. This way you can call the sub when you need to make a new selection on or from a different sheet.
Sub main()
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim Printmanager As PrintManager = oDoc.PrintManager
Printmanager.ScaleMode = kPrintBestFitScale
Printmanager.PrintRange = kPrintAllSheets
Printmanager.Orientation = kLandscapeOrientation
Dim Sheetsize As DrawingSheetSizeEnum = Nothing
For Each osheet As Sheet In oDoc.Sheets
If osheet IsNot Nothing Then
Sheetsize = osheet.Size()
Logger.Info("Sheet object size: " & osheet.Size.ToString & " Sheet size: " & Sheetsize.ToString)
End If
Next
Dim PaperSizeSel As PaperSizeEnum = Nothing
Dim osheet1 As Sheet = Nothing
Try 'Placed into try block as this isnt the best way to get access to the sheet. Try to make it dynamic so this doesnt error.
osheet1 = oDoc.Sheets.Item(1)
Catch
End Try
'Inside the webpages describing each item, you see a numeric value, for example Ddrawing size is value = 9990. You may want to experiment what you need to pass for ojects here
'Strings, enumerators as shown, or maybe change the varable type and simplye use the values. Many options.
Select Case Sheetsize
Case DrawingSheetSizeEnum.kDDrawingSheetSize
PaperSizeSel = PaperSizeEnum.kPaperSizeDSheet
Case DrawingSheetSizeEnum.kA1DrawingSheetSize
PaperSizeSel = PaperSizeEnum.kPaperSizeA1
Case Else
MessageBox.Show("Incorrect size selected doing manual check")
End Select
'Apply the changes to the print manager
Printmanager.PaperSize = PaperSizeSel
Dim sheetwidth As Double = Nothing
Dim sheetheight As Double = Nothing
sheetwidth = osheet1.Width
sheetheight = osheet1.Height
If sheetwidth = 17 * 2.54 And sheetheight = 11 * 2.54 Then
PaperSizeSel = PaperSizeEnum.kPaperSize11x17
Else
'continue depending.
End If
'or again apply the changes as needed
End Sub
If you feel I fulfilled your question, a solution would be greatly appreciated!
