- Mute
- Permalink
- Report
so, to be clear, everyone using Inventor is currently working through the numerous button clicks every time they print to paper or pdf in order to manually match the output Paper size to the drawing size?!
Further, if they want to print a batch of drawings of different sizes - you either must do it in Task Scheduler or work through each one paying attention to the drawing size and toggling the Paper size back and forth as you print each one(?).
It seems to me other programs don't have this issue. e.g. AutoCAD, Word, Solidworks, etc. For example, in AutoCAD it seems that the file contains information regarding the desired Paper size and then when you select a printer, it automatically tries to select that paper size from within the printer drivers options.
I guess I was hoping to find out I had some setting or driver setup incorrectly - especially since nobody else seems to be asking about this.
