kwilson_design
in reply to: WCrihfield
Hey @WCrihfield. I've answered your questions with blue text below.
  • You said your code was running when you save a document, right? Manually running it since I'm just testing, but this will move to an Event Trigger once ready for production.
  • Are you using the iLogic Event Triggers dialog, with that rule listed under one of its events to make that happen?
    • If so, which event (Before Save Document or After Save Document)? Yes, I intend to use Before Save trigger so that user does not forget to run the rule manually.
  • Is this rule in a 'template' file? Currently just testing but yes the goal is to have this in the templates.
    • If it is in a template, then how are you creating new documents from it?
      • Open template, then using SaveAs
      • Or using New command, then choosing template, then Save (which acts like SaveAs the first time) New and then save.
Kenny
If this post solved your issue please mark "Accept as Solution". It helps everyone...really!
