WCrihfield
in reply to: kwilson_design
  • You said your code was running when you save a document, right?
  • Are you using the iLogic Event Triggers dialog, with that rule listed under one of its events to make that happen?
    • If so, which event (Before Save Document or After Save Document)?
  • Is this rule in a 'template' file?
    • If it is in a template, then how are you creating new documents from it?
      • Open template, then using SaveAs
      • Or using New command, then choosing template, then Save (which acts like SaveAs the first time)
Wesley Crihfield
(Not an Autodesk Employee)
