The code is intended for iLogic, it is fully functional, make sure to specify the full path and file name. The full path of the file can be copied using Ctrl+Shift+C.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
