09-22-2024
10:02 AM
- Mute
- Permalink
- Report
09-22-2024
10:02 AM
In my work, I use the following Excel fetch template. Your example will look like this:
Imports Microsoft.Office.Interop
AddReference "Microsoft.Office.Interop.Excel.dll"
Public Sub Main()
Dim oExcel As Excel.Application = GetExcel()
Dim oWB As Excel.Workbook = oExcel.Workbooks.Open(sExcelFile)
Dim oWS As Excel.Worksheet = oWB.Worksheets(sNameSheet)
Dim iRow As Integer = 2
Do While Not String.IsNullOrEmpty(oWS.Range("A" & iRow).Value)
MessageBox.Show(oWS.Range("A" & iRow).Value)
iRow += 1
Loop
oWB.Close()
oWS = Nothing
oWB = Nothing
oExcel = Nothing
End Sub
Property sExcelFile As String = "PathExcelFile"
Public sNameSheet As String = "NameSheet"
Private Function GetExcel(Optional bVisible As Boolean = False) As Excel.Application
Dim oXL As Microsoft.Office.Interop.Excel.Application
Dim oObj As Object = Nothing
Try
oObj = GetObject(, "Excel.Application")
oXL = TryCast(oObj, Microsoft.Office.Interop.Excel.Application)
Catch
oObj = CreateObject("Excel.Application")
End Try
oObj = Nothing
If oXL IsNot Nothing Then oXL.Visible = bVisible
Return oXL
End Function
You need to specify the path to the file and the name of the sheet in the book (lines 21-22).
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
