I can run this rule manually after new drawing but if I put it into the trigger or reference it with any rule triggered by new drawing I get the cable and harness error
Dim oSheet As Sheet
If MyBooleanParam = True Then
oSheet = ThisDoc.Document.Sheets.Item(2)
oSheet.Delete
Else
	Try
	oSheet = ThisDoc.Document.Sheets.Item(1)
	oSheet.Delete
	Catch
	MessageBox.Show("2nd sheet not found?", "iLogic")
	Return
	End Try
End If
