This is a sample, how you can work with OrientedBox of part in assembly context
Sub Main()
    Dim asm As AssemblyDocument = ThisDoc.Document
    Dim asmDef As AssemblyComponentDefinition = asm.ComponentDefinition
    Dim partOcc As ComponentOccurrence = asmDef.Occurrences(1)
    Dim partDef As PartComponentDefinition = partOcc.Definition
    Dim orientedBox As OrientedBox = partDef.OrientedMinimumRangeBox
    PrintBoxData(orientedBox, "In part")
    TransformBy(orientedBox, partOcc.Transformation)
    PrintBoxData(orientedBox, "In assembly")
End Sub
Private Sub TransformBy(orientedBox As OrientedBox, matrix As Matrix)
    Dim cornerPoint As Point
    Dim directionOne As Vector
    Dim directionTwo As Vector
    Dim directionThree As Vector
    orientedBox.GetOrientedBoxData(cornerPoint, directionOne, directionTwo, directionThree)
    cornerPoint.TransformBy(matrix)
    directionOne.TransformBy(matrix)
    directionTwo.TransformBy(matrix)
    directionThree.TransformBy(matrix)
    orientedBox.PutOrientedBoxData(cornerPoint, directionOne, directionTwo, directionThree)
End Sub
Private Sub PrintBoxData(orientedBox As OrientedBox, Optional title As String = "")
    Dim stringBuilder As New System.Text.StringBuilder
    stringBuilder.AppendLine(title)
    stringBuilder.AppendLine(String.Format("CornerPoint{3}[{0:N2}, {1:N2}, {2:N2}]", orientedBox.CornerPoint.X, orientedBox.CornerPoint.Y, orientedBox.CornerPoint.Z, vbTab))
    stringBuilder.AppendLine(String.Format("DirectionOne{3}[{0:N2}, {1:N2}, {2:N2}]", orientedBox.DirectionOne.X, orientedBox.DirectionOne.Y, orientedBox.DirectionOne.Z, vbTab))
    stringBuilder.AppendLine(String.Format("DirectionTwo{3}[{0:N2}, {1:N2}, {2:N2}]", orientedBox.DirectionTwo.X, orientedBox.DirectionTwo.Y, orientedBox.DirectionTwo.Z, vbTab))
    stringBuilder.AppendLine(String.Format("DirectionThree{3}[{0:N2}, {1:N2}, {2:N2}]", orientedBox.DirectionThree.X, orientedBox.DirectionThree.Y, orientedBox.DirectionThree.Z, vbTab))
    Logger.Debug(stringBuilder.ToString())
End Sub
